Coming out of the woods this weekend with the wife driving. 2nd gear, 3,000 rpm down hill. 4,250 lbs gvw, a full off road back country load-out. 31x10.50 tires at 28 psi.
There was a ledge in the road, maybe 10-12"? I saw it, the wife saw it and cruised right over it. Got fully into the front bump stops with no rubbing. The rear hit it, again, fully into the bump stops with no rubbing. The TJ launched probably six inches into to air with all four off the ground on rebound. Landed with aplomb, no rubbing. The bump stops are set correctly, it seems.
The wife laughed hard for probably ten minutes afterwards.
I need to check underneath to see if anything got bent or broken. If so, she's buying me axles!
