Which adjustment moves the shifter?but then I wouldn't get to talk with you!
I know right, I know left, I also know up and down. Your point was?I know right
The cable is used to adjust length between the two shift levers.Which adjustment moves the shifter?
you're having so much fun right now aren't youI know right, I know left, I also know up and down. Your point was?
No, the cable is used to adjust the length between the two shift levers when they are both in the same mode and the in cab is 1/8" off of the end of the gate.The cable is used to adjust length between the two shift levers.
Not really but my cup no longer runneth over so off to packaging I go.you're having so much fun right now aren't you
My point was that he wasn't asking with what you adjust with it, it's what you adjust. Any little kid that is still just holding a flashlight for his dad can tell you that.I know right, I know left, I also know up and down. Your point was?
That kid also knows not to ask a question they already know the answer to.My point was that he wasn't asking with what you adjust with it, it's what you adjust. Any little kid that is still just holding a flashlight for his dad can tell you that.
Maybe that kid just wants reassurance in his answer.That kid also knows not to ask a question they already know the answer to.
Fucking snowflake little bastid.Maybe that kid just wants reassurance in his answer.
I do indeed know what is needed.I need to know why my TC is popping out of 4lo, seeing as your the dude who designed the frickin shifter I'd think you would know what I need to do.
