How to aim Jeep Wrangler TJ headlights
There are two small T-15 torx-head adjustment screws that you can access from the front, between the headlight lense and the chrome bezel. Find the little indentations on the chrome bezels located at the 4 and 10 o'clock positions around the bezel, those give clearance for access to the two adjustment screws. They both aim the headlight so it's a little of both to move it in the direction it needs to go. Top screw for up-down, bottom screw for left-right.
How to align Jeep Wrangler TJ headlights
When lifting Jeeps the headlights are often over looked so use this simple guide to adjust your headlights aiming pionts.
Step 1 - On level ground, put your Jeep vehicle in front of a wall as close as possible.
Step 2 - With tape, put 2 crosses on the wall that correspond with the vertical and horizontal center lines of both headlights.
Step 3 - Move the Jeep back 25 ft., keeping the Jeep centered with the tape crosses on the wall.
Step 4 - Examine the light pattern.
Low Beams should be hitting the lower right sections of the crosses.
High Beams should split the cross hairs.
Turn the horizontal and vertical adjusting screws (located on the headlights bucket) to make adjustments.
