Haha just installed new tires so I won't be the guinea pig in this one! I might try it when they are almost "dead" though. hahaYou could be the first! Test it for us
Excessive tire wear, poor steering, probably unsafe overall.
Thanks!
You'd notice it in the handling, @Vasq is right. Even being slightly toe'ed out you can feel it once you've really paid attention to how a TJ can actually drive pretty well. Don't buy into the "it's a jeep thing" where they are just ratty junk boxes that are fun off road!So, what would be the result if I have more Toe in ?
Let's say for example, 3/4" instead of 1/8".
What would it feel like? What would the disadvantages be?
This is exactly the conversation a had a few minutes ago with a guy, in a local wrangler group. He said: It's a 30 years old Jeep, who cares about this little adjustments?You'd notice it in the handling, @Vasq is right. Even being slightly toe'ed out you can feel it once you've really paid attention to how a TJ can actually drive pretty well. Don't buy into the "it's a jeep thing" where they are just ratty junk boxes that are fun off road!
It's worth it to do it right, in my opinion. If for nothing else than to extend tire life, but it does also make it more pleasant to drive. Not everyone cares to, and it's their rig so they can do thatThis is exactly the conversation a had a few minutes ago with a guy, in a local wrangler group. He said: It's a 30 years old Jeep, who cares about this little adjustments?
An other one said: This vehicle's suspension was designed at WW2, who cares about toe in, I set it in toe zero and I am good to go.
In my personal view, I enjoy "tuning" and fixing every detail in this vehicle. I know it is a Jeep, but that doesn't mean it should not be set up right.
I want to align it on my own as soon as possible, but I am waiting to get the ZJ tie rod in order to not do it twice. haha
My built Jeep drives like a dream, and I have two other stock Jeepās to compare it to.This is exactly the conversation a had a few minutes ago with a guy, in a local wrangler group. He said: It's a 30 years old Jeep, who cares about this little adjustments?
One more question that I have is whether you should align it at 1/16" - 1/8" no matter what Tire size you are running? Is there any difference between this number for 31" vs 33" vs 35" tires?My built Jeep drives like a dream, and I have two other stock Jeepās to compare it to.
No, toe in the same amount.One more question that I have is whether you should align it at 1/16" - 1/8" no matter what Tire size you are running? Is there any difference between this number for 31" vs 33" vs 35" tires?
Thanks for this idea using 2 4ft levels. Worked great although did have āfunā getting the adjustment made. Blaster and Heat are truly your friends.I recently aligned mine with 4ft levels......worked great. View attachment 41593
Not really. If you are off center by inches vertically on the tire it wont change the toe measurements much. I think you might be overthinking the process.Seems like this method is extraordinarily dependent on you perfectly centering your square tubing (or levels or toe plates or whatever you use) with the center of the hub by eyeball, whether the tire is on or off the Jeep.
No I mean laterally. The lateral (horizontal) position of the bars must be identical. Eyeballing it could get it pretty close but we're talking about 1/16" making a difference here.Not really. If you are off center by inches vertically on the tire it wont change the toe measurements much. I think you might be overthinking the process.
are you able to mark the center of your square tube? Should make the eyeballing easierNo I mean laterally. The lateral (horizontal) position of the bars must be identical. Eyeballing it could get it pretty close but we're talking about 1/16" making a difference here.
I just do it with the wheels on, pretty quick and easy process.Seems like this method is extraordinarily dependent on you perfectly centering your square tubing (or levels or toe plates or whatever you use) with the center of the hub by eyeball, whether the tire is on or off the Jeep. You're going to great pains to accurately measure with tape measures, etc. when it all really boils down to you 100% accurately eyeballing the center of tubing to the center of the hub anyway.
Seems the only way to eliminate that requisite "eyeballing" is by using those toe plates that bolt to the wheel studs mentioned in this thread. And those are interesting because they're only like 12" long, they do NOT simulate the actual tire size (33, 35, etc) which we have been told is a required step.
I can see where it would be very easy for someone to be 1/16" off when clamping down their square tubing. Just sayin. I am going to try this myself. Hope it works.
Yes of course, and accurately. The eyeball part is getting that centerline on the tube perfect with the center of the hub on both the driver and passenger sides.are you able to mark the center of your square tube? Should make the eyeballing easier
Laterally it doesn't make much difference. The tubes are the same length so the change at the front is the same as the change at the rear. Like I said, overthinking. Really, it works.No I mean laterally. The lateral (horizontal) position of the bars must be identical. Eyeballing it could get it pretty close but we're talking about 1/16" making a difference here.
are you able to mark the centerline of the hub?Yes of course, and accurately. The eyeball part is getting that centerline on the tube perfect with the center of the hub on both the driver and passenger sides.
Really, it doesn't matter. If you move the bar on one side forward and back the distance between the front and rear sides changes the exact same amount canceling out the difference. No point in adding extra steps to a simple process and adding extra work for everybody else reading about how to do this.are you able to mark the centerline of the hub?
I see what you're driving at. All I'm saying is that with such tight tolerances, getting these marks exactly at the same point within 1/16" seems not really possible. Obviously this method works to a degree, especially when you have toe that is 3/4" from where it should be, like some people have posted about.are you able to mark the centerline of the hub?
What I am saying is that if the bar on the driver's side is even 1/16" fore or aft of where the bar on the passenger side is, your toe measurements and therefore your subsequent toe adjustment will be completely inaccurate. That's the point I'm trying to make. Sorry if I've confused anyone.Really, it doesn't matter. If you move the bar on one side forward and back the distance between the front and rear sides changes the exact same amount canceling out the difference. No point in adding extra steps to a simple process and adding extra work for everybody else reading about how to do this.
This^^^Really, it doesn't matter. If you move the bar on one side forward and back the distance between the front and rear sides changes the exact same amount canceling out the difference. No point in adding extra steps to a simple process and adding extra work for everybody else reading about how to do this.
