How to align your Jeep Wrangler TJ
JMT
Saxum Erepo 🪨
Ok, well thanks. At least I learned something and understand the process better. 👍🏻
TJim
Athens, Greece
If everything in that column is Total, then yes, +/- 0.12, so 0.18-0.42 would be acceptable. That brings 1/16" back into spec since the angle would be about 0.246* for a 29" tire.
Nope. The angle would be around 0.125 for a 29" tire. * I think you doubled that.
So still not back into spec
JMT
Saxum Erepo 🪨
Total, and if spec in FSM is total, then the range is 0.18-0.42* And total toe in for 1/16” would bring you inside at 0.246* for a stock tire.
We’re in agreement.
TJim
Athens, Greece
Total, and if spec in FSM is total, then the range is 0.18-0.42* And total toe in for 1/16” would bring you inside at 0.246*.
We’re in agreement.
Nope. I mean 0.125 degrees total. Check the photo below
Reactions: JMT
TJim
Athens, Greece
I think you're flipping it now. The spec is 0.30 degrees. At 30" that's closer to the 1/16 difference between the front and back. At 35" that's closer to 3/16. It seems you're backing into this one with inches and tire size?
Nope. I just used the other calculator to help @JMT realise that he doubled his result.
As a synopsis, so we don't confuse the matter any further:
30" tire
0.30 degrees total = 0.15"
Range:
0.18 degrees total = 0.095"
0.42 degrees total = 0.22"
31" tire
0.30 degrees total = 0.16"
Range:
0.18 degrees total = 0.97"
0.42 degrees total = 0.23"
33" tire
0.30 degrees total = 0.17"
Range:
0.18 degrees total = 0.1"
0.42 degrees total = 0.24"
35" tire
0.30 degrees total = 0.18"
Range:
0.18 degrees total = 0.11"
0.42 degrees total = 0.25"
etc
JMT
Saxum Erepo 🪨
30" tire
Range:
31" tire
Range:
33" tire
Range:
35" tire
Range:
etc
Now just add to your post the fractions so we can use our tape measure. LOL
5/32” is close enough for a 30 or 31” tire
11/64” for a 33” tire
3/16” for a 35” tire
This is a good argument for going to 35” tires. 😂
Reactions: Mikee024
NskLJ
Long Beach
What is the advantage of removing the tires?
Wouldn't it be easier to jack the front diff, and attach each square aluminum tube to each tire/wheel?
If you used a couple of spacers from the tubes to the rim you could leave the tires on. The spacers would have to be the same length. This is how alignment machine heads attach.
Reactions: Gizmo and TJim
rasband
TJ Guru
Highlands Ranch, CO
Always helping others rationalize the move, it's something we do well around here (y) (y)
Reactions: JMT
TJim
Athens, Greece
OR just do what @rasband said earlier.
Use a convenient measurement.
For example, mark 24" on the tubes. And set the toe in at 0.125" or 1/8"
Bammo68
Western Australia
Both the front tyres on my (new to me) 2001 were absolutely cooked - swapped them out for new Dick Cepek Extreme Country 31's and declined the $150 alignment offered by the tyre dealer. The toe in was set to 20mm by the previous owner. I used a couple of lengths of square tubing and set the toe in to 5mm and the difference in ride and steering was immediately noticeable. Thanks for the thread! The tyre dealer was going on about having to set the caster and the camber and it was a complicated process to align everything - what a load of BS!
I'm doing a front upper/lower arm swap out including the upper frame mount bushings as well as a new adjustable trackbar as some of the bushings look a bit worn - not terrible by any means but cheap insurance against a new set of tyres.
Anyone want to hazard an opinion as to whether that uneven wear was mostly due to the toe-in being far too aggressive?
Reactions: Mikee024 and SvtLdr
