I learned that there are several types of differentials and the parts store have no clue. I was able to get a gasket for Dana 44 rear. Didn't know it was a 44 and neither did anyone else. Felpro RDS6629 gasket. Use Petmatex rtv gasket maker for differentials and transfer cases. Go ahead and purchase a cheap pump. I hade one that I use for outboard motor foot. You can't get oil into fill hole without pump. Everyone got the front wrong. I couldn't locate gasket so just used rtv. I used spray brake cleaner to wash gears for inspection. Took longer than expected because I spent so much time going back and forth to different parts stores. Should take about 3 hours if you have everything.
