Hmmm, that's odd... Sounds a lot like @Tbird Clair's problem!
My check engine light always flickered during "episodes" The idle control valve is what I replaced first... Apparently that wasn't it...
PS: I had the aftermarket/factory "reboxed" TPS replaced as of Monday with a Mopar TPS (via your Amazon link) [emoji6]and the shop reimbursed me the $120 for part they originally installed... Only time will tell, but we've got our fingers, toes, and paws crossed!
This morning (the real test since my engine was cold) my engine started out at 1,000rpms idling. Wayyy too rough.
After that bottle of TB cleaner - I'm thinking that XP985 spark plugs are next on my list.
I don't like ANY of the cheap ass gapping tools that flood the market. Any high quality gapping tools y'all recommend?
Honestly, without a check engine light it's pretty much impossible to know (aside from just slowly replacing everything you can). But aside from spark plugs, next I would probably start with the TPS sensor.
Though if it was me I may just wait until a check engine light comes on.
I am going to do this today. I have some carb cleaner, would that be ok to use?Yes there is a gasket between the throttle body and intake manifold. And yes the IAC will have an o-ring on it.
That said, I don't believe there's any need or benefit to removing the throttle body to clean the IAC. And seldom does the IAC actually need to be removed from the throttle body to clean it very effectively. I feed TB cleaner into the TB while the engine is idling and the IAC will draw the TB cleaner in through itself, cleaning itself in the process. It will not suck the TB cleaner in unless the engine is idling, so don't rev the engine during the cleaning process. The engine will die repeatedly during this process since the cleaner is flooding the inside of the IAC but that's fine and actually good, it gives the cleaner more time to clean. Just restart the engine after it dies.
I try to use a third of the can cleaning the IAC at idle RPMs, then finish the can by spraying the inside of the TB while revving the engine a bit. Every so often I'll let it idle and spray more cleaner at the passage inlet slot the IAC draws its air through, just to make sure the IAC is perfectly clean.
The IAC's air passage inlet is just above the throttle body's valve plate in this illustration...
Me personally, I would go and buy TB cleaner from the auto store. The one that I bought had specific instructions saying to spray it into the throttle intake. Which made me feel better, knowing i'm not gonna mess anything up.I am going to do this today. I have some carb cleaner, would that be ok to use?
I was thinking along those same lines. How did it work out for you? You took off the hose and sprayed the cleaner straight in right?Me personally, I would go and buy TB cleaner from the auto store. The one that I bought had specific instructions saying to spray it into the throttle intake. Which made me feel better, knowing i'm not gonna mess anything up.
I have the exact same one as this post. Can I use a can of carb cleaner/ choke cleaner on this??
