Went to clean mine today and found no bottom screw and the top screw was only threaded in about a third of the way. The IAC was flopping around, wasn’t really any idle issues before. In case anyone wants to know, the screws are 10-24.
Mike, mine has 74k, with just a slightest bounce in tach, and little roughness at idle, ~50-100 RPM variation, and a little rough on start off. What were your rough idle symptoms like?This fixed my rough idle with only 56k on it at the time.
Hey Chris, Stumbled across your instructions today and followed your steps above. My carbon build-up was similar to your pics and parts cleaned up great. Needed to scrub with Q-tips, soaked in cleaner, for the heavy deposits. My symptoms were very mild but now idle is rock steady and silky smooth on start-offs. Thanks for your excellent instructions and pictures. KenIf you're experiencing idle issues on your Jeep Wrangler TJ the most likely culprit (and the first thing you should check) is your IAC (Idle Air Controller). Often times the IAC gets very gunked up causing the Jeep to idle improperly. A simple cleaning is usually all it takes to get it running as good as new.
If you end up needing to replace your IAC valve (they do fail on occasion), you can find the part numbers (and the links to purchase them on Amazon) below:
2005-2006 IAC Valve (Part # 4861552AC)
1997-2004 IAC Valve (Part # 4874373AB)
There is no need at all to remove the throttle body to clean the IAC. This is probably one of the easiest and cheapest things you can do.
Below you'll see a diagram of the top of your throttle body with the IAC sensor labeled.
Take your IAC off (it's held on by two small torx screws). Clean it with your throttle body cleaner, this is what it will look like before and after.
Then take off the IAC housing and both sides (house and throttle body). clean that too. before and after...
Put it all back together and you're good to go. Very, very simple. It doesn't get any easier than this!
Mike,The throttle body did not actually look that bad but if definitely smoothed out the idle. It would decrease in RPM and start shaking slightly, then RPMs would go up and smooth out. Sometimes I thought it would die but it never did. It also seemed worse after the engine was nice and hot such as sitting at a stop light after a stretch of highway. Some might say that was heat soak but cleaning the throttle body fixed it all for sure. I did not take the throttle body off or anything. Just shot intake cleaner in while it was idling.
Seriously Scotty, improved MPGs too?Cleaned mine last week. (That bottom screw was a pain). Results are a smoother idle, nearly eliminated that surge when taking off in first gear, and prob about a 2 mpg increase at the pump.
Yes - Jerry is the one who gave me those instructions. So we know its right!
I took off the intake tube, and gave quick bursts of TB cleaner into the idle air slit that's right above the throttle valve. Then, I sprayed a bunch on top of the throttle valve and revved my engine. I did this until the bottle was empty.
The first few sprays made my engine die, then I couldn't get my engine to die at all. Which I assume means the cleaner worked.
Also, I could literally hear my engine quiet down and smooth out while I was spraying the TB cleaner it. Another sign that I assume it worked!
Have you scanned for codes (on my 03, you can do a key-on, key-off sequence 3 times, the last time leaving the key-on - and any stored codes will show in the odometer; alternatively, take it to AutoZone or O'Reilly's and have them scan.Hi. I am new here with a 2005 Jeep TJ. My vehicle sometimes dies when coming to a full stop. Also occasionally, on a slight incline while stopped, the RPMs go up and down (300 to 1000). It usually normally idles between 600 to 700 RPMs, I think.
My question on Kyle's post is when the engine would not die at all while spraying the TB cleaner, was he spraying while idle or revving? Because I tried doing the instructions from Jerry (use 1/3 of bottle during idle, and the rest while revving), and not sure if I need to continue spraying it while idle, and until it really stops dying. Thanks... Don
All FWIW - I did this yesterday after not being happy with both the idle, and my perception of less than average gas mileage.
Mine is a 2003 4.0L - I pulled the air duct between the air filter housing and the throttle body (and found a cracked PCV vent hose in the process. I also bought a new filter for it, even though the one that was in there wasn't really that bad).
I could not find throttle body cleaner so bought instead a couple of cans of SeaFoam TBI cleaner (I have become a real fan of SeaFoam). Using the included straw, I followed can directions, starting and insuring a warm engine, then liberally spraying SeaFoam into the IAC port and throttle body while the wife held 2000 RPM's. I all but emptied one can of SeaFoam into the IAC and throttle body.
Since doing this, "Oreo" (my TJ's nick name) seems to have a more steady idle, more pep, and the last 1/4 of tank of gas seemed to go further than before. I filled it up today and took a mileage reading. We're heading on a 2 week trip out West Friday - will report back my findings (assuming I don't do O2 sensors tomorrow before hitting the road. 108k miles on what I expect are the OEM sensors - they may also have an affect on milage and performance, although I am not getting any codes).
I’m a little confused about my setup. I don’t have the bolts (screws) it talks about.
Looking at the FSM:
Vs my motor
Anyone know what’s up?
Maybe a screw is missing on yours? Is there a hole there for a screw?I think I found the bolt underneath, and it’s just 1. I’m curious why this looks different than the FSM.
Edit: see page 2, and I’ll probably just follow Jerry’s method of spraying it in while idling.
I would certainly clean the top of that engine up some before I pulled the air tube. Fine particles of dust can wreck havoc on the engine. Granted it probably takes more than what is seen on your engine, but why take chances?
