@zebra12 This kind of flush?
Yes. Just like this. Only messy the first time, new pan will be nice.
I'm not knocking it, more power to ya.its nw florida what can i say
Yes you will have atf fluid going everywhere thats why the write up says to use a 5 gallon bucket. Go to begging of thread and read entire write up. Skim commets after that and you will know eveything you need too. Its pretty detailed you just have to read it.Anyone have tips for the flush portion of this? I have dropped the pan, cleaned, replaced filter/gasket, bolted it back up, and filled lost fluid.
I'm not understanding what to do with the hose to the radiator. I loosened the clamp and tried to pull the hose loose but it wouldn't come off. I loosened the whole nut and everything, but there was nowhere for me to attach the plastic tubing to really. I had atf going everywhere out of the hose and radiator, so I just put the hose back on.
I have a 2001 4.0L 32RH for reference.
I left my pan off for 3 days and it drained 7 quarts. I doubt the torque converter was drained, if you drained and refilled 6 quarts, you still had an additional 3 quarts out of 9 left. In my case I didn't feel the need to completely change all of my fluid as it was a bright red clean and filled properly to begin with.I just replaced pan with one with a drain plug, filter and gasket, got a late start so left it over night with pan off draining. Finished up next day.
So far I have 6 quarts back in and am having issues, do you guys think it drained the torque converter as well?
04 LJ, no trans issues prior.
info i found says 45in pounds for the 42rle.Apparently, there are torque specs for the filter bolts.
@Midnight LJR this looks so fun. (Insert sarcasm here)Ok so I followed the instructions and had the same issue as a couple of other people ATF all over the floor. The fluid runs from passanger side hose into passanger side of radiator. If you disconnect that and attach tube to rad the disconected hose blows ATF all over the place. I cleaned the mess attached passanger side, disconnect driver side and attached hose to driver side rad. Worked after that, i did it in park and didnt seam to have an issue keeping up.
