Not_Invented_Here_
If you can find a local radiator shop, ask them to pressure check, and clean it. If all ok, no need to replace. That's what I did and it cost around $30 in Wichita. He told me to overhaul it, the cost was around $100.00 My 02 water pump was leaking when I did mine at 1320k. I did the complete flush and overhaul of the system. Mine was getting hot and I didn't realize the pump was leaking. I was getting drips from the rear main seal that I thought was a seal failure. When you do replace the pump, that's the best time to do it all again. Are you having any over temp issues?
No, I run at or juuuust a hair above 210 pretty much all the time, just over being in those sweltering KC summers.
In the entire time I've owned it, I had two codes and they appeared at the same time - one related to me needing a new gas cap and one odd random code that indicated transmission running hot months ago. At that time, I did the standard procedure (checked fluid level and color, nothing obvious/odd) and ended up topping it off with some fresh ATF-4. Cleared the code and never had anything since.
I am leaning towards paying Jeep dealer for the full coolant/heater core flush and just eating the cost this time. I have other parts needing to be installed that have been sitting waiting for enough free time and I'd rather take care of this before summer hits since I DD mine.
