which will only help their expensive race team
When's the last year you saw a savvy race team?
How much they charge you? I just got quoted $170 to have mine installed. But that was also one of like 20 other things for the entire project they just line itemed everything.
Year before last maybe?
Anyone got any tricks to get the 2nd bolt off the rear bracket?? Can barely get a socket on the nut but no room to work the ratchet to get the nut off if I could break it free. Looks I'm going to have to pull the drive shaft to get any working room.
Do you remove the four small/tiny hex head bolts on the Cardan joint to disconnect the shaft??
Thanks for the good info here (and another thread it two ). I tackled the Savvy TC cable on my 01 with a 32RH and 231 TC today and all in all not bad. Yes, I have a lift the both helped and hindered me - I would have taken off the skid, but then on a 2 post lift there is little to no support So I had to work around the skid. I am so glad my tool set includes not only ratchet box wrenches but swivel head too! I pulled the front DS or would never have gotten my hands in the space available. the threads here made it clear to not follow Savvy’s instructions to not use the upper TC housing bolt and instead “use the two bottom bolts.” - just use the stock bolt locations.
I said all went smooth, well until I looked at connecting the shifter side quick disconnect .
Savvy sent a QD with a 5/16 x24 stud but a 5/16 X 16 locknut! No big deal I’ve got plenty of nuts and bolts to source from. What stopped my project is the bushing. It’s blasted Nylon! AND it doesn’t fit well. The shifter hole is 7/16 while the bushing is a hair over 3/8 thus allowing the bushing to wobble in the lever. It is also a bit proud when in place which oddly enough will allow the bushing to tilt as well as wobble.
looks like I need to call Savvy tomorrow and get some questions answered.
Anyone else receive the nylon bushing? And I’m always looking to learn if I have interpreted something erroneously.
The nylon bushing is wholly incorrect.
At least 3 of us have received them as of late. Do you have the specs for the metal version so we can order from McMaster Carr or somewhere similar?
From Mr. Lee
Shoot! I just cherck ther bin and all are 5/16”-18. The bolt guy gave us the wrong ones. Sorry!
I’ll get a new one and space out today if I can get the correct jms.
great response.
If someone wants to crank a few out, here are the specs with a few notes.
1- The .625" diameter flange has to be thicker than the recessed area in the levers. If it is not thick enough, then the nut will tighten down and it won't clamp the pilot side of the larger flange into the recess and the stud will wobble.
2- The pilot height is critical. If it is too long, then the bolt tightens down on the end of the pilot and the stud wobbles.
I've got a few parts coming to maybe solve this a different way. All we really need is a thick enough washer that is small enough in diameter to register in the recess. If the thickness is greater than the depth of the recess, then the nut will clamp it properly and the stud won't wobble. The need for a pilot will also go away if the inner hole diameter is correct.
If they work, I'll post up the part numbers and where I got them.
