How To Install YJ Half Doors on a TJ
PCO6
PCO6
Newmarket, Ontario
i know you abandoned at this point, but would there have been anything preventing TJ hard uppers from fitting on YJ lowers once you addressed this pin issue? Is the pin off longitudinally, laterally, or in both directions?
I abandoned modifying the rear most pin on the TJ soft uppers but I did actually fit my TJ hard uppers to the YJ hard lowers at one point. I had to drill a hole through the uppers so I could insert a 3/8" pin down through them and into the YJ lowers. It worked fine. I later filled the holes I drilled with epoxy and then painted the complete uppers. I use them now on my TJ lowers and the holes I drilled can't be seen.
Reactions: freedom_in_4low
APM1
Butler Ga
How hard is it to swap back to the TJ striker once you’ve modified the Jeep for the YJ doors?
CHAWK
Mississippi
From some of the videos I have watched it looks like you can just take the TJ striker off and install a YJ striker vin the top hole and not have to modify the hole at all. I have not tried it yet though.
Reactions: lBasket
