How to remove IAC torx screw?
PamWrangler
Greeley, CO, USA
I need to replace my IAC, but am having a hard time getting the torx screw out. What kind of tool have you used to get enough leverage to get that torx screw from under the IAC loose? I am afraid I may be close to stripping that torx screw!
I use a 1/4" drive torx bit with a 1/4" drive ratchet wrench, no problem. Keep inward pressure on the bit so it stays seated in the screw while unscrewing it.
