Airjunky
So I'm tempted to say screw it & rewire the tailights so they're always on when the key is on.
Unless anyone has any troubleshooting suggestions.
Lol, yep, headlights, front turn signals, fog lights, dome light, reverse lights...... thinking about the center brake light soon.Just curious - are any of your lights LEDs by any chance? Not sure that it matters but I've just been trying to get my arms around all the complexities that seem to come into play when LED lights are introduced - some of the weird behavior I read about kinda reminded me of some of the things you are seeing, but not exactly.
Did you find the combination switch ? I have looked everywhere and find only the single switch to control the lights. If so please provide resource. ThanksI had every intent on doing this fix but then I found the MFS for $144 and it was a MOPAR item so I went that route instead. Still an easy fix, and now my fog lights only come on when I turn them on......
They're two different switches that screw together as they're installed.Are the MFS and wiper switch two separate components ?
So I’m having this same issue where my fog lights randomly turn on but can I just buy a new signal switch like this one put it on—https://www.quadratec.com/products/...MIvJzB3czm6QIVg5OzCh0uvgUuEAQYBSABEgIxG_D_BwEHere's an alternative write-up (though almost identical) to the one @bobthetj03 posted:
My 2003 Jeep Wrangler started magically turning on the fog lights while I had it parked. This issue kept getting worse until I could not get the lights to stay off without touching the switch. At first I was able to put my left turn signal on and this was just a temporary fix. I went to the dealer and they told me the switch would cost me $260 this is why I wanted to fix the existing switch. I want to keep my jeep nice and running another switch somewhere else would just bug me.
This write up includes removing the switch from the steering column.
Tools Needed
First you need to remove the steering the column plastic cover there are two screws in the holes closest to the steering wheel. Phillips
- T20
- T10
- Philips
- Small flat head
- JB-Weld KwikWeld
Now you can remove the two T20 screws on top of the multifunction switch. There are two harness plugs going into this switch which both have a red tab that need to be pulled out (but not completely) in order to be unplugged.
Now the entire switch assembly can be removed.
Next you need to remove the relay, two T10 screws, and the wire plug which has two black wires on it.
View attachment 10688 This image has been resized. Click this bar to view the full image.
Now you need to carefully used a small flat head work your way around the piece being careful not to break any plastic.
Once this is done your switch is exposed and you should be able to see your problem.
A closer look will show you this.
Under the cover you can see what all is happening and why your fog lights will not say off. The white plastic piece has worn down and can no longer lift the metal piece far enough to stop the circuit.
If this seems to be your problem then your fix will be easy. Next you need to remove one more T10 screw. This will now lift out easily but before you do this remove all the pieces on top that are not secured down.
Now you will see the the lifter completely exposed. Pull it up and lightly press it down so you can remove it. I had to slide mine to the left.
Now you are ready to put some JB Weld on the part to build it up to its original length. (I used JB quick Weld but either will work) Before this step you might want to clean the part to ensure the glue will stick. I used side cuts to clean the part up from where it had actually smashed/melted down.
After the glue has dried you can now put it all back together and test it out.
Cool thanks ChrisYes, but you can get one much cheaper here:
https://www.amazon.com/dp/B01NA6A0OF/?tag=wranglerorg-20
Cool thanks Chris
What is Evan Fischer auto parts about? I never heard of them and seems like they have solid prices. Are they a newer competition to Crown?
Not entirely sure, but I will tell you that all of this stuff (just like the LED headlights and Crown stuff) is made in the same factories in China. They just re-brand them under other names. It's the Chinese way of business
