How to rotate tires after adding new tire to old rotation?
EJD
TJ Overlander
1,424
Missoula, MT, USA
Hope that title made sense to someone, but in a nutshell I have recently punctured an inner sidewall while baja-ing through some rocky terrain and have just got the new tire in the mail today.
I'm wondering since I was previously doing a 5 tire rotation, do just put the new tire in the place of the punctured one and continue on as usual?...or since I have the "spare" tire now in the "front passenger" spot, which technically messes up my rotation pattern, should I just mount the "new" tire to the spare location on the back and switch to a 4 tire rotation? or is there a whole other protocol to follow when this sort of thing happens?
The tires are KO2's and they have around or less that 10k miles on them if that makes a difference.
Whats the consensus?
Boinked
2,180
Mesa,az
I would just do a 4 tire rotation. Throw the new on the spare. Once you need new tires go back to a 5 tire rotation.
If for some reason you puncture another tire then you can go to a 4 tire rotation with two new tires to old tires.
That's what I would do
ohiopatriot
699
ohio
Probably 4 tire rotation. Keep new for spare. Depends on tread depth really. Many tire shops can "shave" or match a tire for you .
It may "age" out before you replace the others and get the service life out of them unless you put alot of miles on a DD.
Reactions: fuse and EJD
Chris
Administrator
Staff Member
Sep 28, 2015
35,396
Salem, Oregon
I agree with the above. Only way I would do a 5 tire rotation would be if all 5 tires were brand new at once.
Reactions: EJD
