Sort of an odd question here. Does anyone who has used dynamat know if it is waterproof? Lets say I dynamat my entire interior and it rains in the Jeep. Am I going to have any problems? I'm having my transmission tunnel covered with dynamat to reduce heat from my tummy tuck but I'm considering have the whole interior covered.
It doesn't matter if it's dynamat. As dynamat is no different from the other sound deadener materials. It just costs a whole lot more. You can find the same specs in another sound deadener for WAY less. They are all butyl rubber with an aluminum backing. The better ones anyway. (You generally want to stay away from anything asphalt based. But they are even cheaper.)
All of them are in some way waterproof. As it's Butyl rubber and aluminum. The problem is it goes on in strips. And there really isn't a way to place a waterproof barrier over the seams or the entire install. I mean you could do another layer over the seams. I guess. Or tape the seams with aluminum tape. But it's not a waterproof barrier per se. It's a sound proofing and vibration damper.
I will say the asphalt based stuff is actually a waterproofing layer for your houses roof. So I guess if you installed it and used aluminum tape or a second layer to cover the seams. It could be an actual waterproof barrier. But in a Jeep with a tub. You're asking for trouble because water will pool up in the bottom. And a seamed tape install isn't really the same thing as a waterproof barrier.
Having said that, I don't think if you got stuck in the rain with your top down you'd end up with any significant damage. Unless you left water build up in your tub. And not shop vac and dry it out in say a dry heated garage. Especially just doing your tunnel. Any water would probably just seap right off the sound proofing layer and into the footwells. Either way - if you had a waterproof barrier on your tub. You'd still have to remove the carpet, dry it out, drain any water out of your footwells. And go from there.
Sound deadener isn't really for mud bogging or staying out in the rain with your top down. But neither is carpet. If you want to stay out in the rain. I'd cover the tub with professional bed liner. And not use carpet or sound deadener at all.
This stuff is so ridiculously easy. If you can remove your carpet. (Which is super easy in a Jeep.) you can apply sound deadener. It's peel and stick. And then you use a roller to make sure it adheres to the surface all the way. To do your tunnel would probably take half an hour. And about $30(?) in material. For a normally priced one like Noico. How much are they charging you for the Dynamat?
EDIT - Alot of upholstery shops will apply sound deadener for you. If you didn't want to do it yourself. At least that way you could supply another sound deadener besides Dynamat. Your really only paying for a name in that stuff. And it's ridiculously expensive compared to others.,
