So without rewiring a bunch of stuff i just ended up going back to a remaned one but i tell ya she purrs like a charm now no more sputtering or cutting out on me. Thank yall for all the help.
Jeep alternator was $95, durango was $30...that is the only reason for me... and it works on YJ's alsoI'd be curious to know what the tipping point was though for anyone who has done this!
What model did you use because i have a 06 too and i would like to do This later and want it to be plug and playI have an 2006 I did the Durango swap without changing wires. Going on 3 years.
I ended up getting a NorthStar 34M battery. It has great reviews and I am told it is what is put in police package Chevy impalas so they have enough power. It is a marine battery and is specially designed for high power needs like lights and winches. If I have further power problems I will look into getting the bigger altinator although should never be needed. The price of the battery is a bit steep (about $300) but I am sure will be well worth it. Link belowWhat model did you use because i have a 06 too and i would like to do This later and want it to be plug and play
Thanks
Thanks
awesome thanks man!“This swap should work on all 1997 to 2006 Jeep Wrangler TJs with the 4.0 engine. I don't know about the 4 cylinder engines however. What you'll need is the alternator from a 2001-2006 Dodge Durango 4.7L V8 or the 2004 Dodge Durango 3.7L. Those models have the 160 amp alternator that will work with our TJs, and give you the extra power you're looking for.
The part number for the alternator you'll need is 56029914AA. Both alternators will work, and both are 160 amp. Why they have different part numbers are beyond me, but they are both confirmed as working.”
I believe I went with 2001-2006 Durango alternator.
The HO alternators use a smaller pulley and run at a higher RPM so they require less torque. As long as the belt is in good condition there is no slippage issue. I had a 370 amp (now rebuilt into a 270) in my f150 which has the same type/width of belt. I have never had a slippage issue. The reason you need the shorter belt is because the pulley is smaller diameter.The biggest problem with ultra big alternators is the fact that they require a lot of power to run and there is not a lot of belt contact in a wrangler serpentine compared to a few other models of jeeps...and those dont have enought ribs to stop the squealing either.
I ordered the 2-gauge version from them and installed it a few weeks ago. I don't have high energy demands, but corrosion was setting in (factory cables, 14 years old), and I had already half-assed replaced the fusible link once already (the red-green transition that the OP referred to), and wanted something more stout.So for you guys that are running new 4 gauge wire there is a site that sells a kit to upgrade the wire harness completely. https://www.custombatterycables.com/jeep-wrangler/
I havent done this mod yet but its on my list with an alternator. I got the idea from watching this on youtube:.
Also bleeping jeep has a how-to video for making custom ones yourself:
Just food for thought.
Except for the engine block ground, everything went in quickly and with little effort. The engine ground is a threaded stud that can come unscrewed when you try and remove the nut. My eventual solution was to clamp on to the stud with a pair of needle-nose vise grips with one hand, and an open end wrench on the nut with the other. Until you find the sweet spot, it's a little bit of a contortionist routine to do it, but it's not terribly difficult once you get it figured out.
The alternator part # link goes to a "page not found." Is there an updated link?This swap should work on all 1997 to 2006 Jeep Wrangler TJs with the 4.0 engine. I don't know about the 4 cylinder engines however. What you'll need is the alternator from a 2001-2006 Dodge Durango 4.7L V8 or the 2004 Dodge Durango 3.7L. Those models have the 160 amp alternator that will work with our TJs, and give you the extra power you're looking for.
Here's a brief overview of the install:
1) Disconnect the positive and negative battery terminals first, then the alternator power cable and electrical plug.
2) Using a serpentine belt tool or a breaker bar in my case, remove the serpentine belt.
3) Remove the two bolts that hold the alternator in place and remove factory alternator.
4) Install the 160 amp alternator; it took some finessing and patients to get the alternator in. I ended up having the file some of the factory alternator bracket in order for the new one to fit. Be patient and take your time, you don’t want to damage your new alternator.
*NOTE* The Durango alternator has an extra bracket on top of the unit, it does not come into contact with the factory ignition coil but may interfere when trying to remove the it.
5) Reattach factory serpentine belt and check that everything is secure and in place.
6) Follow the factory alternators red power wire that leads to the fuse box. Mine started red and went to green when it entered the fuse box, your may vary. Cut the green wire and remove the rest of the wire.
7) Take a piece of 4 gauge wire about 25 inches or longer; I picked mine up at AutoZone for a few bucks, and attach it to the new alternator.
8) Unscrew one of the two bolts that hold the stock alternator and battery wire, and attach the other end of 4 gauge wire to it.
9) Reattach the positive and negative battery cables and double check that everything is tight and secure.
10) You’re done!
