Hello everyone, this is my first post. If this topic has been discussed, I could not find it.
Weak air flow and appears to be coming from all vents.
All actuators are moving but air flow is weak. Maybe the arm that the actuator moves is broken. I have heard of putting a screw into the plastic arm to avoid replacing the doors in the box. Can anyone give detailed instructions on which actuator to put the screw into and how? My problem is everything works but blend doors are not moving properly.
I can get my hand in there but don't know where to put the screw or if that even works.
Thanks
Thanks
