So I am having problems with everything seeming to blow out the vents. Well I was able to look under the dash today and I can verify that the panel mode door actuator works properly. It moves fully up and down. So that confirms that I have good vacuum and the lever is not broken. What I notice is I get some blowing out of the floor vents, but when I switch all the way to the right for full defrost...the AC compressor turns on but it is still blowing out the vents...and not much out of the dash upper on the windshield.
I am assuming there is a flap in the upper dash? I would assume I would see it if I fully removed the dash.....not sure if that is correct. What I am looking for is information on diagnosis and what I should be looking for. I really thought the panel mode door was going to be the problem....but again....it fully moves in both directions.
Maybe the TJ is supposed to be this way and nothing is wrong. I mean it has been more than 10 years since my last TJ so I honestly cannot remember.
Any input would be greatly appreciated.
Thank you
Thank you
