I had an overpowering smell of anti freeze in the cab and from past experience suspected the heater core. Using the FSM I removed the steering column, and the instrument panel (dashboard) that exposed the HVAC unit which has to come all the way out. 5 nuts off the firewall, and a couple of hook ups inside and it comes right out. 14 screws removed allow separation of the upper and lower half of the HVAC unit. Note use special care in separating those areas with insulating or seals.
Got the core out and could fins absolutely nothing to indicate a leak. No stain, no fluid, nothing. Well it must be something else so I buttoned it all back up- -About 8 hours of work.
Took it for an extended test ride yesterday. Same smell. Present when heater is on and absent with it off. Has to be the damn core. Fluid must be evaporating before becoming visible. So 40$ to Rock Auto and another 10 hours of work should take care of it. Pictures also show the location of the fan/blower resistor that is a common problem in the Wranglers.
