It was John Cooper’s fault.
I’m not sure how l....but we need to blame him
Was this guy around when it happened?
Don't forget my favorite. Accelera Badak X-Treme MT.
What makes these your favorite ?
I've been looking at these for a bit and the price seems good to me too!
I'd like to buy a set of tires&wheels that I'd only use when going to a trail and have a set only for the street and that being my current setup!
That or a set if interco tires I.e super swamper sx2's or some Trxus radials,iroks Etc. I'm over using my daily setup of tires on the rocks since I chunk them up on rocks and get very bad vibrations once I'm back to a dailying....duh
They seem like they'd be great in mud, but half the price of Swampers. The downside from the reviews I read was they are extremely difficult to balance. Not a real issue since you would want to limit their street use.
wonder if I should be worried about my TEN factory chromo shafts for my Dana 44 once I step up my tire size and HP....
You know I will take the blame, heck I was trying to spot for you and take pictures.
That's never a good combination!!!!!!! Just ask @Hog he will tell you, I can barely walk and chew gum at the same time.....
next time take video so we can see the carnage happen!
Then if you want photos you can just take screenshots.
No sir where we were, I don't think it would have been.
Dang red clay mud is slicker than grease when wet, and traction is almost non existence.
I was actually thinking if I should’ve done it the way Blaine described but then I realized I’d likely got in more trouble because of the sharp drop behind me - This was the kind of climb that you need to be alone on a fairly dry day
Plus- if you look at the pictures it’s a drop off behind you where you make the turn-
I mean it is like to do or die
Then you’ve got to get up on the rock and don’t walk the front end off to the right and flop.
No, I’d start worrying about them now -
They're made in Indonesia, just like my old water monitor lizard. They both have tough sidewalls and plenty of bite.I would be worried about punctured sidewalls on a chinese tire compared to a swamper.
I figured you were older
15 now.
Welp.....dayum
They aren't installed yet since I'm lazy and I don't have the bearings for em so I'll give them a shot....I did buy them new from a guy for 50$ so It's definitely worth the shot!
