I dropped my mini flashlight down the defrost duct in the center of the dash. I'm pretty sure its ALL THE WAY AT THE BOTTOM. And the flashlight is aluminum so I can't use a magnet.
Any ideas???
Any ideas???
He already got the flashlight in there! Saw-sall and get it over withOooo, that sucks. Can you see it , with an inspection mirror and a flashlight maybe?
This is the tool I was trying to describe
https://www.jbtools.com/s-e-tools-7...MI9ubcqsCw7QIV1x6tBh0hGAQDEAQYAyABEgJ5k_D_BwE
You can get them cheaper than $40 bucks, but that’s what I’d try if I could see it.
If you can get a clear visual path, then you may be stuck with leaving it in.
I'm such a dumb ass.
Sadly I can't. Hopefully with the boroscope I'll see it.Not at all!
I just dropped my stubby Phillips down there. I was able to get it out with a magnet on a string though. Can you see it using a mirror?
I'm afraid the duct tape would stick to the sides of the duct before it made it to the bottom. Its pretty narrow and curvy.Coat hanger with duct tape (sticky side out).
I'll give this a try tomorrow. This may be just sticky enough to hold the flashlight but not sticky enough to grab the sides of the duct on the way down. If it doesn't work, I have a mechanical finger coming on Saturday (with the boroscope).Don't laugh, it works, if you can reach it.
Edit: The size and weight of the flashlight may be to heavy, but I've used it to retrieve several things.
https://www.amazon.com/dp/B07PNC9MVT/?tag=wranglerorg-20
Got one on the way. $6.99This is the tool I was trying to describe
I would have tried a lot of things before posting and/or ordering things.I'm afraid the duct tape would stick to the sides of the duct before it made it to the bottom. Its pretty narrow and curvy.
