as you can see in my avatar pic i run the same driving lights i have however moved them from the winch guard to stock fog positionJW Speaker LED headlights and Hella 500 55W driving lights. Mine are mounted on the winch guard hoop, but Savvy has a solution that will work for your hoop-less bumper.
https://rebeloffroad.com/savvy-off-road-light-mount-for-tj-lj-jk-front-bumper/
I wish my lights were round instead of square. But I like the small form factor of the square pods vs the larger round ones I have seen. I haven't seen a four LED light that is in a round housing, but I must admit that I haven't looked very hard.
I put some flush mounted LEDs in the rear bumper of my Titan XD for when I need to hook up trailers in the dark hours. Had to cut square holes with a saw. I have always suspected that if one of the manufacturers of these flush mounted lights would make small round flush mounts, so you could cut holes with a hole saw and drill, they would make a killing!
Nope, not the only one!
Old school halogen KC Slimlites... spots on A-pillars, floods on bumper.
Reminds me of the vampire hunter base station. NICE!!!
Those look pretty interesting and simple. I used the fairlead light adapter for mine in front of the winch and it works well. I am looking to install my wide 40 KC lights on the outer side of the bumper and this will save me from drilling itas you can see in my avatar pic i run the same driving lights i have however moved them from the winch guard to stock fog position
they are the stock mounting hardware that came on them they are the 500 55w as wellThose look pretty interesting and simple. I used the fairlead light adapter for mine in front of the winch and it works well. I am looking to install my wide 40 KC lights on the outer side of the bumper and this will save me from drilling it
Yup, I'm old school too. Daylighters on the windshield, Slimlites on the bumper. Also upgraded the headlights.
Oh I meant the Savvy mounts. Your lights are cool toothey are the stock mounting hardware that came on them they are the 500 55w as well
when i moved them to stock fog location i broke the rusted old bolts so i made my own with stainless thread all and stainless nuts and washers worked great. they are also wired to come on with high beams or switch on separately
and yes wired properly with resistors and fuses
With those windshield brackets, does your antenna hit the daylighter? (I also assume your daylighters are 6")
I think I might go the same direction, maybe driving pattern for my grill guard but not sureI might be the only person who thinks LEDs just don't look right on a TJ.
I've got a set of KC Hilites 6" Apollo Fog Lamps for the grill guard and Long-Range Lamps for the windshield.
That's me on the A pillar plus 3 up front and 2 6" kC driving lights with open covers and my 06 has the skin crawler bumper with 3 round 3.5 inch led and two 4" driving lights ...very effective. I'm adding interior tiny LEDs to light the switch bank unless I get a brainstorm for another way.Yup, I'm old school too. Daylighters on the windshield, Slimlites on the bumper. Also upgraded the headlights.
That's a nice look.
Get a stubby. Works just as good..It'll rub it sometimes. Theres some slight scratches on the side of the light.
