You can buy a brand new from a dealer through them and have the engine installed. It will be delivered to you just as if it was off the showroom floor.
It is. It would be even better in a TJ/LJ IMO.Beautiful though right?
Yes it absolutely does.Unfortunately, V8 does not fit in the TJ :argue:
I bought a complete 5.3 for mine a few months ago to swap in.Unfortunately, V8 does not fit in the TJ :argue:
Wasnt trying to come off as rude. If I did, I apologize. Brightside, the TJ is V8 swappable, so if you really have the dream of having a V8 TJ you can make it a reality.Yes it absolutely does.
I stand corrected :biggrin:Wasnt trying to come off as rude. If I did, I apologize. Brightside, the TJ is V8 swappable, so if you really have the dream of having a V8 TJ you can make it a reality.
They use the factory transmission so the big unknown is how the conversion from engine to tranny is doneWasnt trying to come off as rude. If I did, I apologize. Brightside, the TJ is V8 swappable, so if you really have the dream of having a V8 TJ you can make it a reality.
Not to mention how they marry-up the sensors n gauges to work right, that has to be a nightmare
Nothing wrong with running factory GM harnesses. GM performance builds harneses and ECU for swapped cars and trucks. Pretty cool to see GM supporting GM engine swaps in almost anything out there. If you run a GM engine and use the GM harness and ECU you dont need the Jeep ECU in theory.They use the factory transmission so the big unknown is how the conversion from engine to tranny is done
Not to mention how they marry-up the sensors n gauges to work right, that has to n a nightmare
you can do it !!There's a '48 Willys Overland truck in a pasture with no motor or tranny, it's mine if I want it, I measured the engine compartment, it will hold a Chevy smallblock plan to get it soon
