- Joined
- Oct 4, 2016
- Messages
- 18
Ok guys this is a good one for you. I have a 99 tj with a 4.0 automatic. It started running ruff in the morning. It would surge at the end of the driveway and at a stop light shortly after. When it surges it stalls. Starts right back up. Sometimes it has done it and been hard to start up like the jeep is flooded with gas. Sort of like a stuck choke. (for those of you that remember what a choke is) LOL.
Also every once in a while but getting more than once in a while it will not start cold or stall and will not start. Motor turns over fine just will not fire. Take the coil wire out of the cap and turn the jeep over. Put the coil wire back in to the cap and it fires right up. Found this by checking for spark one day.
I have just had the computer at SLI in IL. and they found nothing wrong with it.
Once everything is warmed up its fine.
The bottom o2 sensor is bad and unhooked. My mechanic is telling me that has nothing to do with it. Opinions?
The jeep has California emissions on it so i'm told. Don't really understand that because its bought in Mass.
It also has a remote starter.
