Hi all,
First off, thanks for all of your help. I've got a 2001 TJ 4cyl manual. I'm not sure if this is in the right forum section or not, but here goes:
A couple of days ago I tried to start the jeep up and I got a no click, no start.
Tested the starter and it works, now I'm in the process of testing if my issue lies in the ignition switch or the wire from the switch -> to the starter.
I took off the ignition switch wiring harness from under my steering wheel and I'd like to attempt to jump my car to see if my problem is the ignition switch, but I'm unsure of which color wires to cross in order to do that (No idea how to read a wiring diagram).
Can one of you smart fellows help me out and tell me which wires I need to bridge in order to see if my car will start? or give me a better method for testing
Thanks! Happy to answer any clarifying questions.
