Rock Toy
I have been hunting this one down for a long time. Glad that I finally got it and installed it. Have to take it for a test drive this evening
It is such a nice table! What are you planning on doing with the third brake light? I have not installed mine yet.I have been hunting this one down for a long time. Glad that I finally got it and installed it. Have to take it for a test drive this evening
I see. I think I will remove the plastic covering and bend the bracket holding the wires to make room for the table. It came with two spacers I am assuming are to make space between the table and the tailgate for those wires. I can't find any instructions about how to modify it and keep the third brake light.Got rid of it a long time ago. 2 brake lights is enough for me
Yes, here's the one I designed and built. Mine has a Molle panel that hinges when the table is deployed, a slide-out table extension/cutting board, and a cutlery keeper mounted to the tailgate behind the stowed table. This video was taken with the table installed on a TJ tailgate in my workshop, I haven't installed it on a Jeep yet.
Wrangler Tailgate Table, Aluminum Alloy Black Rear Foldable Shelf for Jeep Wrangler JK 2007-2017 2/4 Door, Support up to 75lb https://www.amazon.com/dp/B07HQKS7W4/?tag=wranglerorg-20
Looks good! A little over 3 years later mine’s still going strong, I’ve no complaints.
I volunteer to do a long term test on this!
Might either of you be able/willing to grab a few images of where the left upright is attached over the third brake light contacts? I still have the third brake light and need it to pass NYS inspection. I don’t mind modding the plastic cover or ditching it entirely.
Does anyone make a "fold UP" version of a table like this?
I'm too damned tall to use a fold DOWN table.
I'm not running a 3rd brake light, so I'm not sure I understand the question.
You'll have to start a new thread.
Actually I'm testing a new version right now - using most of the same parts, I designed a version that attaches with vacuum mounts. It is mostly intended to be used outside of the vehicle, in this video I'm deploying it on the side of my LJ, although it could be installed on a tailgate using the vacuum mounts:
The new version uses all of the same parts except for how it mounts. The vacuum cups have pumps on them, you can see me pumping them as I'm installing it.
A few photos of it sucked onto my JKU:
The swing-down MOLLE panel is still part of the design, but it's been removed for the video and photos above. It's installed in this photo...
A company has expressed interest in the vacuum version, and a different company has expressed interest in the screw mounted tailgate version so I've suggested that the two companies explore the idea of joint manufacturing - since almost all the parts are the same between the vacuum version and the tailgate versions for TJ/LJ/JK/JL and new Bronco, there are good economies of scale if the two companies work together. I don't know if that will happen or if either version will get into production, but the vacuum version will be on display at Overland West next month to gauge interest.
