If you've never done it, longer. You'll need to make setup bearings and races, buy specialty tools and that's just getting shit for differential work. You'll need to pull the shafts which may require more tools than you have, such as a 36mm socket. I'll tell you that the specialty tools I have for gear jobs cost me $1,200. Although not all needed, here's what I use.
Differential case spreader
ARB shim drive tool
good set of calipers (not Chinense)
good dial indicator w/ magnetic base (not Chinese)
bearing heater
20T press
die grinder to hone inside of bearings and outside of races
in.-lb. beam style torque wrench
Race driver tools
Seal driver tools
My pinion depth tool has helped me shave hours off pinion depth setup
A decent mechanic can get the rear differential gutted in about 1 hour. The front is a bit more involved but should take no more than 1.5 hours. Add 15-30 minutes for a Northeast factor. With proper tools and knowledge, gear setup is tough to estimate but I'd say I average 3 hours an axle. That's sliding the axle shafts back in for final assembly. If it's going to be a one and done, have a shop do it.
