Pretty simple. Plug in the headlight connector and you’ll have normal headlight operation.I bought some new LED headlights for my '04 Wrangler that have the DRL's and turn signals integrated into them (see photos for wiring/Style).
This request comes with the disclaimer that I probably should have researched the "How" portion of the install, and not just the purchase and punt program that I am in.
If you all could be so kind as to put the training wheels on me and nudge me in the right direction (as always), I would appreciate it.
Run the white DRL wire to a keyed ignition source, so maybe find something in the fuse box that is powered only when the key is on, and use a fuse tap. Do it to a non critical circuit, like a hardtop wiper or something like that. They are so low amperage that the “added load” on the circuit will be no issue, but it’s still best practice to avoid doing things like this on more critical circuits.
Wire the green turn signal wire up to the turn signal wire on the front parking light (one per side).
This should end up with normal headlight operation, a white halo when you start the Jeep, and a blinking amber halo when you make turns.
