Installed new window lift struts on back window and they keep popping off when i close tbe window
Gsalas422
Nm
Anybody had this issue I replaced with struts from amazon im not sure what the problem is...it also seems as if the new struts have too much pressure
G
Gsalas422
Nm
No the clips are in it...it seems like the struts I purchased are too strong or require too much pressure to allow the window to close
AndyG
TJ Guru
Lifetime Supporting Member
Alabama
That is a pain- hopefully someone can chime in with the brand they’ve had success with. Any hardtop owners out there with ideas??
JKP
Warner Robins GA
Probably a "one size fits all" strut. The correct ones are matched to the weight of the hood, hatch, etc.
Not something you want to stress too much or you'll be buying the glass as well.
Reactions: AndyG
JMT
The Jeep Guy
I’ve replaced struts but never had that issue. Can you post some pictures of what’s going on? It sounds like if/when you get it shut it just opens again. Is that right?
