Is installing control arms as much of a pain in the butt as it looks like? Getting the uppers in, both front and rear, just looks ugly.
Any tricks to be had?
Good tip! So do uppers, then lowers? Or one side then the other?It was a royal pain in the butt for me, because I was stupid and took all for control arms at once. What a pain in the butt it was to try and hold that axle up by myself, while trying to get the control arms in place at the same time. I won't make that mistake again!
Why are you adding adjustable control arms with only 1" of lift? Just curious.
How about the front uppers? Are double adjustables worth while there as well?When I put adjustable control arms on, I set the lengths on the bottom first, then install them both. After that, I do the tops one by one, set to the manufacturers suggested length. Then I put it on the ground and dial in the pinion angles, which is why I always suggest double adjustable rear uppers, which makes the job so much easier.
All you'll technically need for your tuck is adjustable rear uppers (get the double adjustable ones), but I get what you're doing!
What brand of control arms are you using?
No one makes double adjustable front uppers that I'm aware of. Makes sense if you think about it too, because the front pinion angle never needs to be messed with. The front driveshaft is long enough that it's not a concern.
I found this video because I am considering this in the near future also.
One of the things I want to experiment with is track bar clearance. Put the adjustable track bar in, and then move the axle forwards and backwards to see how much of a difference it makes for clearance with all the other bits under there. Same in the rear. At an inch and a half of lift, it might make or break a setup.
I'm not sure about Rock Krawler joints... Don't know much about them.
The post wasn't about the arms themselves but the video has good suggestions on how to change them. That was the poster's original question.
No worries, I had the same question a couple of days ago and ran across that video, and it made sense. I probably wouldn't go with those arms either. I am looking at the Rokmen and the Savvy at the suggestion of @JMT or possibe the Cores as a suggestion of @Rob5589 and @bobthetj03Oh, I missed that obviously! I thought you were suggesting those control arms.
