1. It's time to vote for the August 2018 "Ride of the Month"! Click here to vote. The winner will receive a $200 gift card from Metalcloak! Voting will end on July 31st.
    Dismiss Notice
Installing Factory Fog Lights on a pre-wired TJ
Discussion in 'TJ How-to Guides' started by Chris, Jan 30, 2017.
  1. dangjalopy
    dangjalopy TJ Enthusiast
    May 2, 2017
    110
    62
    Winston-Salem, NC, United States
    Thanks I found a junk yard that has the harness. I may just do that.
  2. Chris
    Chris Administrator
    Staff Member
    Thread Starter
    Sep 28, 2015
    25,122
    14,386
    Salem, Oregon
    Good call, that's what I'd do. Then it will be just like factory!
    dangjalopy likes this.
  3. dangjalopy
    May 2, 2017
    110
    62
    That's my plan. I don't need the glitz and glamour.
    Chris likes this.
  4. piratemonkey
    piratemonkey TJ Enthusiast
    Nov 4, 2017
    171
    118
    Australia
    @Chris Did your silver TJ have the rear fog light?
  5. Chris
    Chris Administrator
    Staff Member
    Thread Starter
    Sep 28, 2015
    25,122
    14,386
    Salem, Oregon
    I never had a silver TJ. You mean my black TJ?
    I don’t think TJs ever came with rear fog lights. Not to my knowledge at least.
  6. piratemonkey
    Nov 4, 2017
    171
    118
    Australia
    Sorry man, the original post had pictures of a silver TJ so I assumed that was yours.
    My TJ has the factory rear fog light.
    The stalk has two pullout positions, the first does nothing and the second is the rear fog light.
    I’m assuming the first is the front fog lights and hoping that its as simple as adding the lights and a relay and they’ll work.
    I don’t have wiring in the inner guards but inside the engine bay on both guards I have the plugs pictured below.
    Can anyone confirm those are the right plugs?
    Here’s a picture of the factory rear fog light.
  7. Chris
    Chris Administrator
    Staff Member
    Thread Starter
    Sep 28, 2015
    25,122
    14,386
    Salem, Oregon
    Ahhh, that's a European / Australian thing. None of the TJs in the U.S. ever came with those (or those twilights either). That has something to do with local laws. Vehicles in the U.S. aren't required to have a rear fog light.
    Someone such as @Kiwi TJ or @Daz7 can hopefully confirm this, since they're from New Zealand and Australia.
  8. piratemonkey
    Nov 4, 2017
    171
    118
    Australia
    Cheers Chris.
    What's twilights?
    Is your plug the same as what I have?
    Out of interest, on your stalk when you pull the knob out to turn the fog lights on, it there a second indent? (can you pull it out further)?
  9. Chris
    Chris Administrator
    Staff Member
    Thread Starter
    Sep 28, 2015
    25,122
    14,386
    Salem, Oregon
    I meant to say taillights, oops!
    U.S. spec TJs have a different looking taillight. It's been a while since I looked at my taillight plug, so I can't comment on that 100%.
    Nope, on my TJ you can only pull the knob out one time, there is no second indent. It sounds like that second indent on yours is supposed to turn on the rear fog, in which case, the stalk that comes on the Australian spec TJs must be a different part number than the U.S. spec one.
    piratemonkey likes this.
  10. piratemonkey
    Nov 4, 2017
    171
    118
    Australia
    I’m not sure they would do a seperate switch.
    They like to keep things globally simplified hence running the same harness throughout.
    This got me to check mine again.
    The combination is as follows:
    -parking lights (rolling the knob forward once)
    -headlights (rolling the knob forward again)
    -front fog lights (pulling the knob out one indent.
    -rear fog light (rolling the knob forward whilst front fog lights are on)
    Cheers
  11. piratemonkey
    Nov 4, 2017
    171
    118
    Australia
    To throw more confusion mine does not have the wiring for the spot lights.
    Not sure what the three wire plugs are on top of the right and left guard, but in trying to find out I checked the relay wiring check the colours only to find out I have no wires running into that spot for the relay. DOH.
    I'll have to try find the full loom.
  12. piratemonkey
    Nov 4, 2017
    171
    118
    Australia
    I’ve managed to source a NOS OEM fog light wiring harness.
    One I track down some fog lights I’ll post my results.
Share This Page
