I’m hoping someone has experienced this problem and can provide some guidance. I have a 2006 Jeep TJ X that I bought about a month ago, I’ve had a few other wranglers but this problem is completely new to me. When I bought the Jeep the odometer was working fine but the other day it started displaying all 8’s. I did the instrument gauge test and 2 faults showed up:
Bus bO and open panel
I haven’t been able to find much about these faults anywhere online except that Bus bO has something to do with not communicating with the PCM. I pulled out the cluster and cleaned all the connections checked all the wiring that I could get to under dash and found no issues.
Furthermore, when I attempted to scan a check engine code I had to install a fuse so the OBDII would work. With this fuse installed on port 26 labeled accessories on the under the hood fuse panel, the 4WD light on comes on and stays on. This only happens with this fuse, and not without. However I have checked and I am in fact not in 4WD.
I’m stumped at this point and would appreciate any suggestions.
Thanks in advance
Thanks in advance
