Hi all, I am stumped and hoping for some help...
2000 sport... auto/6 cyl
I cant get the part time 4x4 light to work, nor the parking brake light....
I have check the parking brake ground switch under the center console and it is working correctly.
I have tested the instrument cluster by holding the odometer trip button when turning the car to on and I see most of the lights test correctly, but not the brake or part time 4x4 light.
I have removed the cluster a few times, swapping bulbs/connectors and it looks like the voltage isn't making it to the bulbs, as bulbs/connectors that worked on others didn't work on brake and 4x4 part time.
I've also tried removing and attaching the brake sensor under the master cylinder to see if that would help, and no luck. I think I even crossed the lines and retested and still nothing...
I know veteran drivers will tell me to leave the lights off... My son is a young driver and I want the warning lights there in case he forgets 4x4 is on or the hand brake is up....
Any ideas? Thanks all....
-Steve
-Steve
