TJ Fest 2021
Interesting JP tire comparison
Jeff Allan
When I was searching for info on tires over the last few weeks, http://www.fourwheeler.com/how-to/wheels-tires/154-1110-power-and-performance-from-weight-loss/ was one of the articles I found. Thought I'd share it as I found it really interesting to what we like and talk about. It's pretty much common sense that more weight at the wheels means a reduction in power and mpg... But I thought it'd be much more than what it really was. Very surprising at 28 #'s more per tire(!), mpg only dropped .63 mpg less. Now the HP and 0 to 60 times is more in line with what I'd guess.
For while I was scrutinizing over a few lbs. because I was reading all these guys saying for every lb. of unsprung weight, it's x10 in the jeep. they had all these calculations and stuff...it made my head spin more than my wheels.
There's also other factors which may it incredibly difficult to really know, like rolling resistance. What I read about the Duratrac is it has such good grip/traction and softer sides, that it can have more rolling resistance. Then there's tread depth which they say factors in. So many variables, you don't know until you know.
Chris
Administrator
Staff Member
Florence, AZ
Yep, in a lot of ways this is one of those things where you don't know until you know.
Adding or reducing weight from rotating mass makes a HUGE difference though. MPG aside the best thing you can do when increasing tire size is to re-gear your rig. I went to 4.88 gears with 33" tires and my auto tranny and it's a night and day difference. Worth every penny!
Reactions: Jeff Allan
billiebob
Kootenays, BC, Canada
Gas mileage? Rolling resistance? Watch Tour de France. Ride a Mountain Bike... Then ride a Road Bike. Tires are the most important, easiest to change factor affecting gas mileage, rolling resistance. But to make a real difference the change needs to be dramatic. Which we TJ drivers tend to do to in the extreme to reduce our fuel economy.
Alex M.
Yeah, us TJ drivers are doing the opposite thing that most people are doing with their tires =]
J
Jeff Allan
28#/tire is what I'd consider dramatic change. yet the fuel savings is so miniscule. Even the HP didn't really suffer that much. Now the author of that article is surprised at those numbers and how much change resulted..... I guess he didn't read all the forums first. ha.
billiebob
From the article.. "A pound of rotating mass is like 10 pounds on the Jeep” for us Jeep-speakers". So 28# is 280# or 1000# total weight saving in Jeep speak. I know Driving alone or with 3 big guys as passengers makes no difference to my highway gas mileage... at least not a measurable one. And if the 2 tires are the same dimensions with the same tread? Good luck measuring any gas mileage difference.
For tires to make a difference they need to be real skinny and have no tread and run at higher pressures. Look to a Bonneyville Salt Flats racer for low rolling resistance which might make a measurable improvement.
Reactions: Bermudacat
mrblaine
TJ Guru
Quail Valley, CA
I think the biggest issue with not understanding the difference weight makes to our rigs is very few of us actually wheel where it makes a difference. If you aren't at the limit of performance, then anything you've done to hamper that performance won't be readily noticeable. As for the 3 large passengers, any effect they may have will be overcome and made less noticeable by your highway speed. If you get above around 60 mph, the wind resistance will make any other issue seem a pitiful detractor in comparison.
J
Jeff Allan
When I haul gear, I can feel it harder to accelerate, and braking distance longer. Maybe not as noticeable on highway, but around town, I can feel when there's a lot more weight in the jeep. 1000 lbs. would be helluva lot, in a jeep. I don't know about the 1 lb=10 in the jeep. I read several times it's 4 lbs.in the vehicle for every 1 lb on the wheels, or below suspension. It's for every 10 lb.s, lose 1 HP. ha, who knows...
Sasquatchewan
Laporte Texas
I could tell the difference in the width of a tire probably due to weight alone, but I still run a 33" KM2 but 11.5 instead of 12.5 made a good difference, also better steering response.
Bermudacat
Great looking car. Form Follows Function and that looks like a ton of Fun!
