I started my ‘06 X 4.0L last night and it immediately revved to 3000 RPM. Tried twice more and same issue. I did notice it didn't start right up the first try, kinda hiccuped then turned over. After cussing the motor for 5 minutes it started fine and I drove to store and back without a problem. Also started fine this morning. Had similar high rev issue last year & cleaned throttle body, IAC (which is only a few years old), and replaced TPS. The problem persisted until I finally found a missing bolt on top of intake manifold. But that was a consistent problem each time I attempted a fix, it never went away until I found missing bolt.
The air temp yesterday was mid 90’s, only drove maybe 6 miles or so around noon. When the high rev issue presented was just after a thunderstorm and 10 degree drop in air temp, approx. 6:30PM.
Any ideas?? I didn't have a chance to get at it last night and start poking around, so just wanted to throw this out there to see if anyone's experienced the same. If it's a vacuum leak again, I would suspect it would be a vaccum leak every time I started the motor, not just 3 times and all's well after.
