Thank you in advance of any and all assistance...
Was given (red flag
) a 2005 TJ that did not run and looked like hell. Two owners before, someone had tried to steal it, the ignition guts were hanging down. I put in a new battery, starter and serpentine belt. Drained the gas and added fresh. With the old screwdriver trick, it started right up
! Checked compression, strong and consistent.
For maybe 20 starts, the screwdriver tricked worked...then (now getting to the meat of the thread...the intermittent issues began.
Often, it would start right up, sometimes when I turned the key (screwdriver) the dashboard lights and associated buzzers would illuminate but no crank, sometimes turn the key and nothing, and sometimes, would crank but no start and sometimes, would start idle for a bit then stall.
Looking for the logical problem seems to me to be the ignition switch. I am assuming that using a screwdriver on it is hard on the internal workings.
I am leaning towards and I hope would be an easy fix by just replacing the switch (minimal
I have read that a bad ground can lead to some funky symptoms like this. I at least know that the neg battery terminal to the body and block are good.
Thoughts?
BTW I did surf the other threads and didn't find one quite exact for the subject.
Was given (red flag
Thoughts?
