Howdy folks...been lurking over this forum for months... figured I'd sign up and introduce myself.
Bought a 1997 TJ back in March. Paid way too much for it. Came with a 4" lift and it needs a clutch.
Added a winch plate and a Warn winch and the Stienjager Shift cable kit.
Been struggling to get the skid plate down. Has a 1" spacer...or had one...the bolts were all 5/16" hex heads and they were all stripped. Got one out welding a bolt to the head. Finally got the torch out, cut through the 1" square tube and just torched off the bolts...with a jack holding up the AX15 of course.
Searched the common repairs thread and ordered new nutserts from Black Magic. Two of them have bolts...well...now studs... spinning inside the frame.
Also considering ditching the "shovel" and just fabbing a new cross member with .250 wall 1" x 4" tube and a .250 flange. That way I'm ready when I Dana 60 and long arm this pig.
Working my way towards the clutch. Along the way going to rebuild the 231 with a SYE and driveshaft and eliminate the 1" drop.
And pull the exhaust, drop the pan and replace every seal on this thing since just about everything is seeping fluid.
Thanks for the good posts! Lots of good Intel here!
Check out my YouTube channel:
https://youtube.com/channel/UCae8cq236PAPnXXzyZigKkw
Have some posts getting the TJ stuck in snow and some other misadventures.
Thanks!
Mac
Thanks!
Mac
