IPerkWVU's Shale Green 04 Rubicon Build
IPerkWVU
IPerkWVU
544
506
Indianapolis, IN, USA
#41
Tested out the antirock today, felt more stable on the trails and I loved not messing with my disconnects. Heading up to Badlands in Attica IN was the first time on the interstate, little more sway but nothing too bad.
Good time with a few jeeps, got some trail riding in and tackled a few obstacles.
A nice TJ we wheel with, currie lift on 35s done right. I was able to follow him up the "waterfall".
Likes: Fouledplugs
Farmergreg
Just a "Web Wheeler"
271
258
WC Indiana
#42
Cool vid. We took my stock LJR up the concrete hill on 31's....more of a crawl (I'm an old man!). No spotter, got hung up at the top break over. Backed down a little and took another line and made it over.
(After harvest, I've got a low pro transfer case skid to go on)
I've got to get a proper rear bumper added to the build pile with an integral hitch. I can't attempt the "waterfall" with the trailer hitch below the stock bumper.
IPerkWVU
IPerkWVU
544
506
#43
I've gone down the waterfall when my TJ was stock with a receiver hitch, it definitely scraped, didn't attempt going up when stock. Since the lift I can go up and down without too much trouble now. Badlands is fun just because how close it is. We had planned to go to Haspin Acres this past Saturday but the rain kept us away.
IPerkWVU
IPerkWVU
544
506
#44
A few small updates from the past few weeks. Got a Teraflex hand throttle installed, tested it out in 4 low and like how consistent I can set throttle is, especially in 1st gear. Won't be using it much unless I'm in 3 pedal situations but it's nice to have.
Also finally got the Mopar Rock Crawler bumper on. This one was a project, found it rusty at a scrap yard, had it sandblasted, cut a small amount of rust off the tubes then coated it in rattle can bedliner. Happy with the outcome.
Likes: isu2815
IPerkWVU
IPerkWVU
544
506
#45
Well I finally sold the E36 M3 I had for around 10 years, took a little longer than expected but I wasn't in too much of a hurry, I knew where the local BMW club was having their Christmas party so I went and parked it in the lot ahead of time with a for sale sign. It worked, sad to see it go but didn't need both the M3 and the TJ.
The BMW allowed me to pay off a few things and some funds for jeep mods, specifically a TT.
Planned out a budget friendly, hopefully install friendly Tummy Tuck. Ordering has started, most parts should be here within the next week or two.
With the jeep having some miles on it, frame in OK shape I looked for a few areas to save some coin. The 2"+ gains I'll receive should meet my wheeling needs just fine.
Previously installed
+JKS 1.25 BL
+Brown Dog 1" MML
Parts Ordered
+Core 4x4 Tier 2 adjustable rear upper control arms -$170 w/ eBay coupon
+UCF Original Extra Clearance steel skid w/ locker mount - $320 w/ holiday sale
+Savvy cable shifter -$170
TW driveshaft - will order once measured
I'm sure I'll have some questions as I put it all together, with the weather it may take me some time to get it all sorted but wanted to take advantage of the holiday sales.
IPerkWVU
IPerkWVU
544
506
#47
Got the Warn sliders on, the 03+ Versions dont have the rear most hole drilled out (it is centerpunched under the PC) since you have to drill out an access hole by the seat belt. Warn gives you good instructions on how to do so. I don’t see how you could actually use them without drilling the last hole so that’s what I did. I’m referencing the bolt that is circled in red. I do think they could have added one more bolt location underneath the Jeep logo, there is a small gap there. Also needed a few additional thick washers shim the tubes that brace the gap between the tub floor and the slider. For the price I’m happy with the results, much stronger than the OEM Rubicon sliders.
