Tj04
Yes it absolutely is an ideal weapon for home defense. Compare ballistics and dry wall penetration, etc to any pistol or other rifle caliber and it is absolutely one of the best choices. Only in 5.56 does this apply. Start taking heavier 300 AAC mods or 6.8 through it and it looses many advantages.
If safety is a concern e.i. Neighbors, then yes a 55 grain hollow point round will get less penetration through household walls than almost any other gun.
And also one thing many don’t know: a 9mm or 45 etc will penetrate 3 times as many interior walls than a 5.56.
Shot placement is key with anything. Know you’re target and beyond. Don’t shoot your kids.
If you live an an apartment complex do not use a shotgun. The .40 caliber balls inside most 00 buck are capable of far more penetration through walls than many including myself would have expected.
If you use a shotgun use Buckshot #4. Number 4 is what many agencies are switching to for this reason: LESS penetration thru walls to avoid killing others in adjacent rooms.
All this is discussed probably daily on most gun forums. No matter what you get a huge array of opinions.
Go look at ballistics from a home defense standpoint. You might be surprised what you learn!
What matters most is you are confident in your weapon. Safety should however be a primary concern among anyone living in an urban area.
