WolfeJeepTJ
Wow. $2.99 here in San Diego, Commiefornia!$1.56 per gallon here, no worries!
Ha! Tell us all about your TJ... tire size, engine size, transmission type, and if you know it what axle ratio is installed. Just over 10 mpg can usually be helped.so I just sold my old fun driver - it got slightly worse MPG then my TJ.....but it was 35' long , weighed over20,000 lbs and had a 8.2l Detroit diesel turbo - and still got over 10mpg!! TJ is getting just a little better than that!
CRV doesn't give good milage at all. I get 16 in city and 22-24 on Freeway.Even a CRV doesn't get that grade of gas mileage, ask me how I know. Definitely better than my TJ but nothing spectacular.
500 miles in a TJ with 4 people? - I call shotgun!!My wife's 100 percent stock 2004 TJ, 4.0, NV3550, 3.73, with 30-9.5 -R15 @ 30psi.
got 26.1 mpg with summer spec. gas.
This was on a 500 mile road trip on 2 lane Colorado highways with 4 people at 65mph.
Buy comparison our 2.5 l. 5spd. Subaru Forester AWD would only get 28 mpg on the same trip.
That's one of the reasons the Subaru had to find a new home.
Sorry that's my wife seat!! My 2 grown daughters rode in the backseat with500 miles in a TJ with 4 people? - I call shotgun!!
Not comparable from gas to diesel without math. Diesel contains approx 138,000 btu/gal and gas 115,000/gal (winter) plus a compression combustion engine is more efficient than spark ignition engine. Generally more compression= better efficiency. I get what you are saying though- our little aero bricks don't shine for mpg but sure are better on the trail than that 35' long rig.so I just sold my old fun driver - it got slightly worse MPG then my TJ.....but it was 35' long , weighed over20,000 lbs and had a 8.2l Detroit diesel turbo - and still got over 10mpg!! TJ is getting just a little better than that!
Our 2008 CRV gets at least 27 hwy. My 2004 stock height wrangler 4.0 42rle 3.73 on 30 × 9.5 stock wheels will do 18 or better hwy in summer with the Softopper on it. 16 mpg hwy in winter with the hardtop.CRV doesn't give good milage at all. I get 16 in city and 22-24 on Freeway.
Your mileage may vary.........I think it's funny when people claim a Jeep, EPA rated at 19 mpg highway on a closed course, under ideal conditions, get 23-30 mpg under normal driving conditions. I'm guessing they bought one of these.
p.s. I ran a couple of my Jeeps from FULL TANK to OUT OF GAS. 18 mpg highway was the best I ever got. Now I don't care.
Sort of. The way you drive does matter, the drive cycles, the road type, wind, elevation, any warm up, etc. The EPA ratings are not the automakers choice to publish. It is a predetermined series of drive cycles at given temp and not on street gas. Test is done on indoline. So yes- some can do a little better and some a little worse. Wildly different numbers from EPA ratings are almost always people checking MPG incorrectly. When I wanted to test a fuel or a car i tried to run a replicated route and closely comparable weather over 10 tankfuls. Even then you need to park at the same pump, same direction, and either let the nozzle self click off (pretty variable even at that) or fill slow to overfill. Folks just don't do that. EPA at least weighs the fuel even though they use that stupid indoline. The other big variable is winter vs summer. Winter temps, winters dense heavy winds, winters low btu gasoline fuel (more volatile light ends) make it a lot harder to get respectable MPGs.EPA is a very bottom baseline. If I ever dropped down to EPA numbers on any car I've owned I'd be checking the drivetrain out to see what was wrong.
Driving like a sane person helps a lot, learning how to drive to maximize mpg helps even more. Not many people bother with any of that. So the manufacturers aren't going to quote numbers that most people won't get.
Cold air intake, Tornado, fuel line magnet plus some “miracle” in a bottle. Fuel milage should doubleI think it's funny when people claim a Jeep, EPA rated at 19 mpg highway on a closed course, under ideal conditions, get 23-30 mpg under normal driving conditions. I'm guessing they bought one of these.
