it's the check valve in the fuel pump outlet,
So Jerry the check valve is apart of the fuel pump assembly ? and replacing the assembly would fix the problem?
If the leak down only occurs after the Jeep has been sitting a while, like overnight, it should. Leaky fuel injectors, a broken fuel line fitting, etc. can also cause the problem but it is usually caused by the check valve in the fuel pump.So Jerry the check valve is apart of the fuel pump assembly ? and replacing the assembly would fix the problem?
I'd just replace the entire thing with a Bosch unit.
This one to be exact:
https://www.amazon.com/dp/B000CF6084/?tag=wranglerorg-20
Hey Chris I just want to make sure im ordering the right fuel pump. the above part number is 67659. i have a 97 tj 6cyl. I read in a different thread where this part number was recommended Bosch - 67756.. can you confirm which I should order. thanks man .
Do you have the 15 gallon or 19 gallon tank? That one I linked to was for the 15 gallon tank. The 19 gallon tank unit is this one:
https://www.amazon.com/dp/B000BZJDK2/?tag=wranglerorg-20
Part number 67756 does not fit your 97.
Dang I dont know. my owners manual says 15 but 19 optional . so how in the world besides filling up when empty can i find out.? Ill get back to you when I find out. but if its 15 ill order the 67659Do you have the 15 gallon or 19 gallon tank? That one I linked to was for the 15 gallon tank. The 19 gallon tank unit is this one:
Napa is 50 bucks cheaper and you know you will get a real Bosch item.
https://www.napaonline.com/en/p/BSA67655
SO my gas tank part # is 52018768 and the ASSY# is 52100310AA I think that is a 15 gal.Dang I dont know. my owners manual says 15 but 19 optional . so how in the world besides filling up when empty can i find out.? Ill get back to you when I find out. but if its 15 ill order the 67659
there are way to many chinese knock off's on amazon right now. that claim to be the real deal. I have lost trust in amazon.I got mine on Amazon, it’s a real Bosch item. Why wouldn’t it be?
https://www.cbsnews.com/news/amazon-walmart-newegg-third-party-sellers-sell-counterfeits-report-gao/
that report is just for 3rd party sellers. but i have a hard time beliving amazon doesn't buy 3rd party stuff and resell it under their own name too
this is ridiculous , i go to the MOPAR web site and type in the model number from the gas tank and it says " Oops! No records matching with your search string"
so ive been looking all around on the web and come to find out ( if its true ) that all the tanks are the same size , but it has to do with how far down the vent tube goes into the tank. It also said if you have a 15 gal tank and cut the vent tube off that extends down in the tank that you would now have an 20 gal tank, BUT .......
this is getting crazier by the min.
wondering if Jerry or mrblaine would have any info on the subject?
It is the same tank with just a difference in the vent hose length. 15 gallon capacity tanks are actually pretty rare in our TJs, only the most stripped down basic models came with them. Most who think they only have a a 15 gallon tank are actually just a victim of the inaccurate fuel gauge whose pointer notoriously indicates lower than the level really is.Sounds about right. I looked at the part diagrams and I only see one fuel tank for 97 models, which is listed as a 19 gallon tank.
@Jerry Bransford, do you know by chance if the 15 gallon tank was a different tank altogether, or if it was the same as the 19 gallon tank?
So Jerry, im trying to buy a new fuel pump,( to fix my slow to crank problem) do you know which bosch pump I need to buy? is it the one Chris listed ?earlier 67659 or for the 19gal. 67786 ?It is the same tank with just a difference in the vent hose length. 15 gallon capacity tanks are actually pretty rare in our TJs, only the most stripped down basic models came with them. Most who think they only have a a 15 gallon tank are actually just a victim of the inaccurate fuel gauge whose pointer notoriously indicates lower than the level really is.
