I wonder (with my tiny little brain), if aluminum-wrapped poly foam is any better for preventing melting the PE foam versus simply running the rubber insulation version that has a 40* higher heat rating.
If just running from the orifice to the firewall, there's not as much heat over there so I wouldn't worry about it as much. Split rubber insulation would be easier to install than the tape because the line runs really close to the fender and around the outside of the PDC so there's not much room to work with if you have to wrap it.
If insulating the part of the suction line that runs over the valve cover and intake all the way to the compressor, that's where I'd be more concerned about it. The aluminum really only helps against radiation, so it's what I would run if there was direct line of sight to any part of the exhaust. But short of that, the rubber is probably better.
