ive got bothAn angle finder to check the pinion angle and a tape measurer for the new driveshaft.
Ah okay that makes sense. Glad I've been too lazy to install it I guess. I'll save that for when I work on the tuck then and get it with the adjustable TBThat straight bracket is likely not going to work. When you tuck the drivetrain, the pinion has to point upwards also. The TB bracket rotates with the pinion which ends up binding the bar in a straight bracket.
Did you ever pick up the Savvy transfer case cable shifter?Update: I now have
SSSYE sitting in a box
Track bar and angled bracket installed
Grinder ready for spring mount trimming
lock ring pliers incoming
Upper and lower double adjustable CAs in the rear
What am I missing?
I'm gonna get that when I get the TTDid you ever pick up the Savvy transfer case cable shifter?
We were all just testing you. Congrats, you passed!Transfer case fluid!... I can't believe none of you reminded me smh... at least I remembered myself
Don’t forget the TC fluidTransfer case fluid!... I can't believe none of you reminded me smh... at least I remembered myself
I just got off the phone with Tom Woods, he said said the same thing to meHey bud not sure if this is already mentioned here but since we're kinda at the same spot thought I'd let you know.
Just called Tom Wood's about the driveshaft for the SYE - I was worried I might have to buy a new driveshaft again down the line between the tuck and potential additional suspension lift for me in the future (currently only at 2"). He said if I get it with measurements before the tuck and then push everything up they can adjust it for the difference for about 70 bucks. And they should be able to lengthen it for something similar if I down the line add more suspension lift.
Dang and here I was thinking I was being helpfulI just got off the phone with Tom Woods, he said said the same thing to me
Same lolOh I did ask about prepaying without measurements and he said eh just wait til you can measure
I'll be finishing up the install today, and my driveshaft should come in next Friday@thekidwithquestions. Finally, is this going to happen? Does your wallet feel lighter or did you have to pawn it? Rooting for you.
Then a TT down the road? How much tuck? What skid?I'll be finishing up the install today, and my driveshaft should come in next Friday
