Is my winch rope still okay to use?
Palmy
New Zealand
Hi everybody,
I used my Warn winch for the first time, but I completely forgot to install the fairlead onto my bumper. Is this ok to still use? Or do I need to buy another...
Thanks!
MichaelGH
Hemi ‘97
Lifetime Supporting Member
OHIIIIIIO
As stated above, that section of rope minimally needs to be cut out…
inkedrose
washed up superhero
Arvada, Colorado
@Palmy , Don't be scared to cut and splice, do it once and it's super easy. There's a few videos on here or youtube. Tool you want is called a FID. Factor 55 makes a tool that cuts time significantly but its pricey for what it is. I used a buddies and ended up buying myself one
jjvw
secret beadlocks
Colorado, USA
Sharpie makes a good tool, as well.
Jerry Bransford
TJ Guru Moderator
Staff Member
Fleming Island Florida
Cut that section off and attach the rest of the good rope back to the winch drum. I wouldn't attempt to splice the line back together unless you really, really know what you're doing.
Reactions: RangerTJ
RangerTJ
Georgia
If that section is near the end, cut it off and live with a slightly shorter rope.
There's no way I would trust that section for recovery.
Did it rub against the bumper cutout for a fairlead?
Reactions: Jerry Bransford
RangerTJ
Georgia
He is probably either dead from his line breaking and dropping his rig on him or his radioactive spider has managed to knit him up a new line by now.
Hey, it was only a bit over a year ago (wish I'd seen that before I replied :unsure: )
That synthetic line lasts a long time and winch line technology has probably evolved in that time frame. 😁
bucky
SoCal/North Dakota/ N Az
I need to install the thimble I got from Wizard Recovery on my Superwhinch S 9500 SR. What size FID do I need? Since I will be using this tool once in a blue moon will a plastic one be acceptable?
mrblaine
Crew Member
Quail Valley, CA
@mrblaine, I’d like a good fid. All I have is a plastic one that is tedious to use. Is this a good one?
https://www.knotandrope.com/collect...ucts/yale-tubular-fids?variant=21734444400688
No idea. I operate under the premise that this shit is basic, needs to be able to be done in the field with minimal tools, and a bit of knowledge is far more important than anything you can buy. The ONLY caveat to that is perhaps a small pair of "dyneema" specific scissors to make that a bit easier. I do all of my splicing with one of those tedious plastic fids and a roll of cheap electrical tape.
The only thing I ever do is buff the sharp edges off of the point on my jeans so it doesn't snag the individual fibers.
