I posted a pic of my filter in a previous thread as Jerry B asked if my filter was anti drain back and it is the correct Ryco type.What oil and filter are you running? Lifter tap/rattle is common with the 4.0.
Puts my mind at ease a bit, Its hard to record a noise that's so quick and doesn't happen again until its left for a long overnight period at least 12-14 hours plus.There is a small timing chain guide on these engines, but no tensioner. Off the top of my head I would guess that you're hearing the hydraulic lifters rattle a little on start up before they pump up. Could mean it is time for new lifters, but not necessarily an urgent need.
can you have somebody start it up for you while you listen with a mechanics stethoscope? I don't hear a lot about chain rattle with these engines, but we hear about lifters all the time. My 99 did the same rattle on a warm startup just like a cold one, though when warm it seemed to go away more quickly. Still lasted at least 30 seconds though, and it was less of a random rattle and more a definite tap that corresponded with camshaft speed, and was heard loudest under the oil pan so there was pretty much zero doubt about it being in the region of the camshaft and lifters.Just realized the short rattle at cold start up also happen on a warmed engine start up that has been parked for a while on an Incline!
Any thoughts am still steering towards chain rattle.
Cheers
