Is the Warn XD9000i a good winch?
Electrical looks good, but I’ll have to test everything to make sure the solenoids are good.
Might need a new remote since the Evil Winch Doctor said these weren’t the best and one of the pins is slightly recessed.
Reactions: Blackjack
The drum looks good. Corrosion and rust on each outer end. I removed it all and gave each end 2 coats of clear. I’ll paint the inner part of the drum tomorrow.
I ordered 4 new electrical boots and the special grease @Blackjack mentioned. I also got 4 3/8-16 square nuts and 4 3/8-16 1 1/4” bolts with lock washers to bolt it to the Warn Rock Crawler Bumper! There were other odds and ends I needed and got those on the bench waiting.
@Blackjack is sending me the insulators, bus/bar, and a lot of other stuff I need to restore it to good working condition. Stuff that I can’t find or is hard to get. I’m really thankful he has a penchant for these winches because he’s been very helpful.
Oh, and one more pic at the bottom. That’s what I found when I opened the electrical. 🤨
Before I forget you will not want to mix the new grease with the old so just use the new stuff on the bushings since the gears look good.
Reactions: JMT
The drum was cleaned of all rust. Self-etch primed, satin black enamel and 1K gloss clear. @Blackjack is sending me a number of parts. When they arrive I will get it all back together, strip, mask, prime, paint, and matte 1K clear. I emailed Warn to tell them I’m resto’ing an xd9i and requesting decals. We’ll see!
@Blackjack
I need one of these where the cables pass into the housing.
I ordered new electrical boots. How do you put the new ones on the cables?
Prepping the outer housing for fresh paint. I think I’m going to use a metallic black or straight satin. I thought about going back to the factory gray, but it doesn’t really go with anything on my Jeep. 🤫
Reactions: matkal
People who paint over stickers suck.
I also really love the people who paint bolt heads so I get to clean all the paint off. 🙄
@Blackjack, you mentioned doing something to slow corrosion on the motor. What we’re you talking about?
@Blackjack
I ordered new electrical boots. How do you put the new ones on the cables?View attachment 324518
That grommet is PN 27124 I do not have a good one right now but Six States can get you one or Montana Jacks has one in stock. The boots slide on the cables with a little effort. Make sure to grab some Ultra Seal from Six States to protect those connections.
Reactions: JMT
It will make sense when the mailman drops things off but I will say you need a tube of either Ultra Black or Ultra Grey Permatex depending on what color you are painting the motor.
Reactions: JMT
Oh, to cover that hole between the end cap and motor housing. Got it! I still have some of The Right Stuff - 1Minute gasket maker.
I remember Earl Scheib when they did a complete car paint job for $99.95 in the 80's. Door seals and everything got painted. :LOL:
Yep too much time and money to mask stuff off. In the heavy equipment world they call it a Ritchie Brothers rebuild named after the auction company.
Reactions: JMT and flyinfish
We had an chain outfit in California in the 70s called "Autorella" - make your car a Cinderella, $79.99 full paint job. Just like you describe: Minimal to no prep or masking!
Reactions: Blackjack and JMT
Dang I missed following this as I have a bag of the boots I'd bought to do my rebuild.
  • Sad
Reactions: JMT
