Remember about a year ago, one hell of a fight broke out on this site about the cold air intake.
There is a difference between
It is not worth the effort.
Stock filters will filter better.
Nothing to be gained.
Who was announced as the winner, and will this be an annual event?
Where would you say the small change in the dyno HP numbers come from? I know that video was a 4.0 as nobody is running dyno numbers on the 2.5. Lol.So here is some rough math just for fun. So 151ci at 5000 (not realistic I know) rpm pulls 175 cfm. Stock air filter flows 320 cfm brand dependent. So really other than packaging issues there is no reason not to use the stock air box.
Still have the cat on it?
I'll add gutting or removing a cat will do absolutely nothing for power either....unless yours is plugged. Ive tested that one on more than a few vehicles even bench flow testing them seeing 2-3 times the flow capacity and still Nada in the way of performance gains on the vehicles.
It's not as simple as that.
What is “plugging”?
The cat is gone. It is loud. I’ve replaced motor mounts and timing chain, but she’s still too loud. Do you think adding the car back would quiet her down?
It would make some difference and help bring back some needed backpressure.
Airbox flow?
Is a CAI pulling cool enough air?
No. Saying "engine X flows this and intake Y flows that which is more, so any changes to intake you make are pointless" is not correct. Using an intake's maximum flow number tells you almost nothing. Just like all those electronic cooling fan numbers you see advertised that mean zero. The pressure differential and how that effects flow does. How much vacuum (restriction to flow) does X filter create at what power level (WOT at 5k rpm) is what the engine cares about.
It also cares about how much dirt it is sucking in and I'm not advocating people run CAIs. I'm just saying understand how it works.
