They had me at:
Strike Force Zebra airCommand!
Apparently yes.I see some of the new air compressors "shut off" at a pre-set PSI. Is it possible to make a air inflator hose with a regulator so I don't have to baby-sit and sample filling progress?
Sad to say I just finished up an Arduino controller coupled to four relays for my lockers and air system that controls the compressor, and all the valves including the blowdown on the compressor and I never thought of adding a pressure transducer to control the compressor at low pressure which is what it looks like that thing does. And of course the transducers are about $20. I do like the hard shutoff of the manual switch but it looks like I could plumb in a transducer and still use the standard switch as a backup. Not going to help anybody else though but why not a month ago when I started this project!!!
Could be worse, could be Fortran. It's really just C so if you can navigate that it's easy. Most people don't really even do any coding, they just tweak the extensive library of examples out there to a particular application.Oddly enough they're programmed in Pascal
Or Assembler, or machine language for that matter…Could be worse, could be Fortran. It's really just C so if you can navigate that it's easy. Most people don't really even do any coding, they just tweak the extensive library of examples out there to a particular application.
PIC and assembly is where I got started, good times.Or Assembler, or machine language for that matter…
…yeah, I go way back.
