Alright, so the current project started as a ZJ Tie Rod conversion on my pretty much stock Jeep TJ. For some history, here's my current setup:
1. 1.75" Zone Spring Spacer
2. 1" MML
3. Savvy 1.25" Body Lift
4. 33" Tires
5. Zone Shocks (14.5" Compressed/24.5" Un-Compressed)
6. Factory bumper trimmed with added winch plate, bull bar, and Warn 8,000lb winch.
Since I had the front end taken apart anyway, I decided to replace my 20-year-old factory springs that had almost 2" in sag. I ordered the 2" BDS springs in the hope to replace the spring spacer pucks as well. While everything was off, I went ahead and cycled my suspension and came out to needing about 1.5" added bump stop and therefore will just be keeping the 2" extensions that came with the Zone spring spacers.
While I was doing this, a question came into my head. My ultimate goal with this Jeep will be to do the 4" Currie Lift. But that won't happen for about a year. However, if I have the correct bump stop for my current shocks:
Is there any issue with going ahead and installing the shock length I'd ultimately want with the 4" Currie lift? I.e. would a longer shock right now limit me in any way? I'd think the bump stop setup now would prevent the shock from ever bottoming out. What am I missing? Or is this an okay idea?
Second Question:
Is there any harm in keeping the front 1.75" spring spacer WITH the 2" lift springs to help 'level the rake'? I wouldn't keep the back spacer and I do have the 1" MML. Would the 1.75" spacer cause issues with the rear driveline angle?
2. 1" MML
4. 33" Tires
Second Question:
